Seat Inca 1.9 Diesel 2000 does not start hot
14 years 6 months before #21007 by manual-mecanica
Hello everyone.
I have a small problem with my Inca Seat, which does not start (sometimes yes) and when it does not start you have to wait for 20 min to start what can it be and what budget can be the repair?
14 years 6 months before #21018 by manual-mecanica
Manual-Mecanica Response on the Re: Seat Inca 1.9 Diesel 2000 does not start hot
Mmmm This hot Arranke theme is half complicated because they can be several things, but I had a similar case and the problem was hot Arranke Ke increases its resistance and also turns less times from what I had to do in cold, this is not seen with the naked eye but it was effective and worked, here in Chile it came out for the value of 70000 thousand pesos luck
14 years 6 months before #21049 by manual-mecanica
Hi Azpil. You do not tell us what kind of smoke you have when it starts, something else, are you trying to stop by compression when starting the rotation with the starter? - In every way the injection time, valve calibration, fuel return and air filter. Luck.
Miguel
14 years 6 months before #21055 by manual-mecanica
hello. Thanks for the answers, but they have told me that it can be a sheet under the steering wheel that serves as a bridge with the contact and the pump, I am not able to be the technician:(
in the story know the failure I tell you.
14 years 6 months before #21107 by manual-mecanica
This problem shows that it is the 109 Refer that is above the fuse box. Change it or you can bridge the contact to ensure but it is a failure that is usual.
