Daewoo Lanos 1.5 Soch 2000 does not start .... Help ...
14 years 6 months before #20916 by manual-mecanica
Good morning gentlemen:
For a couple of days I noticed that the car was downloading the battery and no fuse was flying, check an alternator and found a defective rectifier, as I was more than 10 years Spark, ... Maybe I moved some cable but everything seems to be in place, ... how do I check the signal to the coil? ... position sensor? ... Does anyone have the diagrain of ignition? ... help
in advance thank you very much ...: UNSURE:
14 years 6 months before #20990 by manual-mecanica
You have to check the nconector that reaches the coil first of all but if the vehicle party and now not, I do not think it is a kisas problem you went to carry the cable of this sensor.
14 years 6 months before #21005 by manual-mecanica
Thank youssss
the sensor connector was lazy, at first glance it did not seem but when I moved it to verify if it was connected it was released ...
Thank you very much ...
14 years 6 months before #21016 by manual-mecanica
For that we are friend, when you kill
