Problem problem Lambda Ibiza 2003 Motor Bby
14 years 6 months before #20826 by manual-mecanica
The problem is that the Lambda regulation is fine and the fault is sporadic
14 years 6 months before #20882 by manual-mecanica
It is called broken or broken cable or makes contact and does not do if it is a sporty one as you say
14 years 6 months before #20907 by manual-mecanica
Something similar happened to me in a Chrysler but it was only a failure in one of the connectors that was released with the slightest impact, but sometimes it connected alone, so when you find the fault, I only repair the connector. And to date I had no more problems that is more than a year, otherwise change it since the fault factors must also be what I name Kikemec ;) B) ;) B)
14 years 6 months before #20997 by manual-mecanica
Solved problem, I have changed the probe and solved. But the main problem I have had in this case, that is why I have consulted you is that the beloved Lambda Vale probe (204.63 euros), so I had to have it very clear to change it. Many thanks to all and even another.
