Problem problem Lambda Ibiza 2003 Motor Bby
14 years 6 months before #20800 by manual-mecanica
The escape gas light is turned on. PROBLEM ELECTRICAL FAILURE IN PROBE HEATING1 BANCO1, SPORISH. I check heating and it is fine I check installation and it is well deleted, I make a tourage of the Test 40km witness off, stop the car and the time approximately I start and again light on and the same fault. see if there is someone with a similar case and has been solved. Thank you
14 years 6 months before #20801 by manual-mecanica
Hello many probes have a heater that feeds with 12v and they have an TMB fuse it is possible that the probe is no longer in conditions to follow its operation in short circuit you must change RLA but first check the fuses greetings
14 years 6 months before #20810 by manual-mecanica
If the truth is that the probe can be in cut but have a sullen when the Catalitical is in poor condition also ring a fault with the oxygen sensor or Lamda probe of the one bench one, soin if the Catalan is very bad the sensor is the sensor and sends a blacksmith to the computer but because of the problem of the Catalitic not of the probe.
14 years 6 months before #20822 by manual-mecanica
Change the probe
14 years 6 months before #20825 by manual-mecanica
If 12v gets to the probe and after traveling those km it persists you does not change it
