Golf 2003
17 years 10 months before #2070 by manual-mecanica
Golf 2003 posted by Manual-Mecanica
It marks an open door when it circulates only on occasions when it passes a pothole or a road hit
17 years 10 months before #2129 by manual-mecanica
Manual-Mecanica Response on the Re: Golf 2003
: S I have the same problem at that door and the bell is too annoying, I imagine that it can be some false contact in the some relay or even put everything loosen in the sheet, which is where a micro that marks the open or closed door is close
17 years 10 months before #2131 by manual-mecanica
Go thinking about buying a new lock, the story is that inside the lock there is a micro that is touching in the ratchet, which is seen with the open door, the ratchet is lined with a plastic that to the rubb The micro but it will not mark you in the painting when the door opens, nor will the alarm sound to you and if it is why you enter the car after a few seconds, the car will be closed only by not detecting that the door opens.
17 years 10 months before #2132 by manual-mecanica
