I need the tuning of the Renault Kangoo
13 years 9 months before #30812 by manual-mecanica
Manual-Mecanica Answer on the Re: I need the tuning of the Renault Kangoo
Hello good night I am not sure but I think that the piñon of the cranks has a notch in a tooth is corresponding to the PMS. Some belts are marked with the cranks and camshaft marks and the distribution scheme comes from behind. I also think that I have more data at work tomorrow I try to send you, keep in mind the skates the fixed and the tensioner are not expensive and if one is flu, the breakdown is important. Greetings.
13 years 9 months before #30835 by manual-mecanica
Hello, look in the engine steering wheel has a brand that is a line that you have to coinside with the brand of the box that is finally in the direction of normal engine, when you do coinside this brand you will see that followed by it is a semicircle made in the steering wheel that is seen when you coincide the lines, and the other one that you have to take into account is that the amount of teeth is between the pump and the 19 for k9k
