White smoke
14 years 7 months before #20469 by manual-mecanica
White smoke posted by Manual-Mecanica
I have a Toyota 2L 2188CC engine, I had a change of hoops and I keep throwing abundant white smoke accompanied by lack of strength, thank you so much information about
14 years 7 months before #20519 by manual-mecanica
Manual-Mecanica Answer on the Re: White Smoke
The white umo is due to water vapor,
I mean that water is entering the cylinders.
Board of Bad Board, Bad School etc ...
I don't know what you will have done !!!!!
Salu2
14 years 7 months before #20544 by manual-mecanica
Hi Juam, first the white smoke as the 1979 friend says is because of the water that enters the combustion cameras, but to be able to give you more information you need to know what work you did in the butt if you rectified or brush or why you changed rings, broke or only wear. Well Juam I hope I have served you, good luck .....
14 years 5 months before #21844 by manual-mecanica
Holla, I recommend you disassemble the cylinder head and bring a precion test to berify little internal leaks between cooling and lubrication cameras.
14 years 5 months before #22019 by manual-mecanica
If it is white you have to see if it is steam, if so, water is entering the cylinders as everyone says. But if it is smoke it is oil. It may be the valve seals (if you did not change them) or set yourself if it is not the oil that is left in the escape (this option according to the time elapsed since you started it), and as a third option and last it may be that the point has been behind (this can be due to lack of strength).
