TRANCHING IN THE TRANSMISSION
17 years 10 months before #2043 by manual-mecanica
TRACK IN THE TRANSMISSION PUBLISHED BY MANUAL-MANICA
I have the transmission a little fucking, the left and right joints are not bad at all, but what is the entry of the transmission to the gearbox has a little olgure, and when I limit a dump pothole, I do the endures or change for some repaired that come out to 80 euros each, I also change the sinnebloc of the arms and I had the direction that the direction aligns to me. At all because the car turned more than the account to the right side and faster tb backstock, that was because they had not focused well the direction or because they had not adjusted the liquid regulation screw well not?
17 years 10 months before #2066 by manual-mecanica
Manual-Mecanica Response on the Re: Tracheteo in the transmission
Esmeralda, what car are we talking about exactly?
Another thing, what oil regulation screw do you mean? Normally, if the car goes to another side or it costs it to turn more to one side that is usually due to the geometry of the direction, which they have not left well.
It could be the case that you had the orbitrol of the direction badly, but it would be a lot of chance that you would go through the workshop and just fail, right?
With respect to the transmissions, you have answered alone, it is better to change them for some repaired, because with clerious slacks, the least that can happen to you is that you break the striatum of the gearbox and that was going to make you funny ...
greetings !!
17 years 10 months before #2115 by manual-mecanica
Sorry for not explaining it well, Ibiza-Cordoba, the direction was centering the car when the cineblock was changing, in curves it was not going well, I had the right shock absorber very sunk, however it was not bursting, the shock absorbers have changed and as the focused was done with the sunken damping, because now that it has its normal height the direction is no longer well Little by little, but before focusing it, it would be good to take advantage of and change the address, a greeting and thanks for the discomfort, there is a clarification of the nick is not xica, that it would not be bad that there was any, is that the page does not take my name or my name or my mail so I had to open an account with the name of my Movia osse
17 years 10 months before #2122 by manual-mecanica
I know you are not an aunt!, The aunts are not pringuishing the hands in the cars ... hahahaha.
Greetings and do not walk experiments, take it to make the parallel that you are going to liar brown.
By the way, have you painted something already with the new gun?
17 years 10 months before #2141 by manual-mecanica
Heyyyyyyy as you have remembered the jajjjaj gun, ma surprised, after I am also experienced with her, with a bad piturilla I am painting the gossip that I see that they are already very bad, the other day I paint some tires of a tractor, now I am fixing an oxidao agricola trailer, putting remembrance and that to see how it looks ... hahaha good a greeting and thanks Megabeat for enduring the silly questions of the rookies, although to see if they find out that from here the problems are not fixed only, that the problems have to be solved them alone, well almeos encouragement for all those who are liaos .... hehehejjjjjj
