Problems with Daewoo Lemas
14 years 8 months before #20352 by manual-mecanica
PROBLEMS WITH DAEWOO LEMAS Published by manual-mecanica
Hi friends, if you can help me
My 1994 model is spraying gasoline, the spark is there but it won't start at all. It's a GDI engine. I measured the compression and it reads 50, 55, 60, 50... Can anyone help me please?.
If you have the manual for this model, could you please send it to me?.
thank you.
14 years 8 months before #20354 by manual-mecanica
Manual-mechanics response on the topic Re: PROBLEMS WITH DAEWOO LEMAS
Hello, good evening.
You know, you've given us very little information. I'd like to know how this problem started and what unit of measurement you used for the compression reading, because if it's in PSI or kg/cm², it's very low. Please let us know.
14 years 8 months before #20359 by manual-mecanica
Very little information, please correct the compression measurements, in which unit they are, and how the vehicle failure started.
14 years 8 months before #20372 by manual-mecanica
Thank you first of all, try to scrub it and I start it.
