I have problems with Daewoo Lemas
14 years 8 months before #20332 by manual-mecanica
I'm having problems with my Daewoo Lemas. Posted by manual-mecanica
The engine was running, they rebuilt it and the head gasket blew... I replaced the head gasket and now it won't start at all. The timing is perfect, the spark plugs are firing, the injector is spraying the fuel, but there's no explosion. I've checked everything and it still won't start. I measured the compression: Cylinder 1 - 70, Cylinder 2 - 70, Cylinders 3 and 4 only measure 55 and 50.
Any help would be greatly appreciated.
14 years 8 months before #20355 by manual-mecanica
Manual-mechanics response on the topic Re: I'm having problems with Daewoo Lemas
Hi,
maybe I can help you here. If you have spark and good fuel injection, and the timing belt is in good condition, my question is whether the engine has hydraulic tappets, and if so, did you prime them before installing them? Let me know...
14 years 8 months before #20358 by manual-mecanica
Hi, if you already checked the compression, do it again, but first add a little oil to the cylinder before checking the compression and test it again. If the compression rises from 70 to 150 or more, the problem is in the cylinders, and if the compression only increases by 30 or less, the problem is in the valves
14 years 8 months before #20370 by manual-mecanica
Thanks my dear friend, I got it started.
The problem was very low compression in the cylinders. I injected a little oil into each cylinder, towed it, and it started.
14 years 8 months before #20371 by manual-mecanica
The compression only reaches 75 in all cylinders, but it recovered a little and I started it anyway.
Thanks.
