Ford Transit
14 years 7 months before #20154 by manual-mecanica
Ford Transit published by Manual-Mecanica
Hello everyone, I have an incoment, I must change the olio of the change cafa of a Ford Transit val
14 years 7 months before #20155 by manual-mecanica
Manual-Mecanica Response on the Re: Ford Transit
Hi Puma_01. From what you say it seems like a clutch problem, which does not finish off the disc. Transit usually carry on the right side of the change an 8m black/m screw, flat and wide. It will be more or less at the height of the transmission retainer. I ran into one that had no emptying plug, it was a 2.2TDCI of 2004.
You are lucky ...
14 years 7 months before #20159 by manual-mecanica
Hello podas, thanks for your interest but the bomb and the bombin are new the TMB clutch is new I do not understand why it would have a problem suddenly
14 years 7 months before #20161 by manual-mecanica
Try to give another bleeding to the circuit, in case you have some air. Even so, try to put 2nd and without releasing the pedal puts the 1st. If it enters well, it is the problem of the hydraulic actuator that does not move enough the pressure plate.
14 years 7 months before #20162 by manual-mecanica
I will provise that, because when the first hard entered it launched then the others enter well I will try to purge a little more although everything is new as I said before bomb bonbin and the clutch, well I will try that and I hope it is nothing serious, thank you
