I have an optra with a transmission problem
14 years 7 months before #20042 by manual-mecanica
I have an optra with the transmission problem published by Manual-Mecanica
Good for everyone, first of all, I would like to help me with the corp that my optra must. It is the P1779_ defective tcil circuit. Searching online and found only according to the code that is transmission and the fault code is 6009. He who has some information is very appreciated ...
thanks ..........
14 years 7 months before #20062 by manual-mecanica
Manual-Mecanica Response on the Re: I have an opra with transmission problem
Hello, I will see me in an injection sensor, what car do you say it is?
14 years 7 months before #20083 by manual-mecanica
Hi, you think it is the injectors the car is OPTRA DEINT 2008. The computer ring the following code P1779_CIRCUITO TCIL defective, that according to a extracted information from the Internet is transmission but I do not know what it causes ......
If you can help me I thank you very much but much ....
14 years 7 months before #20089 by manual-mecanica
Hello, you will see this model in Europe, but well, the acronym for T cil means OSEA cylinder position that thinking about the cylinder sensor. Sorry because my program does not locate this failure. GREETINGS
