Ford Mondeo accelerates alone
17 years 10 months before #2004 by manual-mecanica
Manual-Mecanica response on the Re: Ford Mondeo accelerates
I would thank you if you can take photographs of the sensor that you disconnect. Thank you
17 years 10 months before #2005 by manual-mecanica
Easacatly the one that I disconnect is that of the Black butterfly box, the idle valve is already correct the cleaner and the bellows is not broken because it makes liquid brake cleaner on one of the sides and did not pass the other, when it connected it to the current with the valve in the hand it moved when giving the contact, thank you.
17 years 10 months before #2008 by manual-mecanica
Then try changing the TPS, but first finds out its cost since they can sell it with the full injection body, consult its value but I think it is a bit high. greetings
17 years 10 months before #2010 by manual-mecanica
I have already asked the price of the TPS is 103 and more VAT and it is sold loose, I am not happy this afternoon I have gone to the scrapping and I have brought 2 for 20 e on Monday or Tuesday I will tell you if it was that for tomorrow I looked to change the distribution strap and I do not know if I would finish it on Monday, thank you.
17 years 10 months before #2011 by manual-mecanica
Ok on Monday you tell me.
