Noise by turning right
14 years 7 months before #19831 by manual-mecanica
Noise by turning right published by Manual-Mecanica
I have a 206 ago `little I change the tires of about 14 to 17 and it makes me a noise when I turn to the right and I have noticed that the right wheel is stuck to the fender than the right please see if someone can give me some indication about it.
14 years 7 months before #19834 by manual-mecanica
Manual-Mecanica response on the Re: noise when turning right
Good flat. Since you put on some of 20 ".
Surely they touch you in the plastic of the wheel steps, it usually passes. It is solved by placing some 2cm separators with double centering, what happens is that then it is possible that the wheels of the fins leave, so the P-206gti carry some moldings that make the fins bigger.
I hope it serves you something ...
14 years 7 months before #19845 by manual-mecanica
Thanks colleague I'm going to see
