Relay problem
14 years 9 months before #19825 by manual-mecanica
Relay problem published by Manual-Mecanica
Hello very good to have if someone throws me a hand, I have a Ford Orion 1.6 90 hp carbureation and it stays accelerated to about 2000 laps, if I start in cold it stays in 1100 and in piece to go up or to go down as if it were going to penetrate and when it heats up it is when the revolutions go up
it is urgent to me because I work with the I hope someone answers me
thanks a greeting a greeting
14 years 9 months before #19827 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with the relevant
Good afternoon Jose. You have to check the tube that goes from the admission collector to the servofrane (master), you may be broken and have an air intake.
Have luck ...
14 years 9 months before #19830 by manual-mecanica
Thank you very much I will look but that was what else could it be
14 years 9 months before #19832 by manual-mecanica
Hello again Jose. You would have to check the carburetor and make sure that cold start is not hooked. A valve that carries carburetor on the right side, which makes the cold engine a bit accelerated and as he heats returns to the resting posture.
14 years 9 months before #19833 by manual-mecanica
That valbule is black round and a spard comes out
