My Opel Corsa does not start.
14 years 8 months before #19719 by manual-mecanica
My Opel Corsa does not start. Posted by manual-mecanica
:( You see, my car has been parked in the same place for a week without starting it, and today when I was about to take it, knowing that it would cost him a little to start well, and waiting for that to happen, I have put the key I have given the contact with the foot and the throttle gait and the accelerator given, and he has penetrated and when trying to start stepping on the accelerator repeatedly, I have not managed to get out, and I wanted to know if anyone knows if anyone knows if anyone knows if anyone knows if anyone knows if anyone knows that I don't know if it will be a battery or some piece that fails, if someone can give me a solution ..
14 years 8 months before #19732 by manual-mecanica
Manual-Mecanica response on the Re: my Opel Corsa does not start.
I do not understand when you say "knowing that it would cost you a bit to start well", the first thing you have to verify is the battery because if it is dead, it will not reach the fuel pump. Try to give more character. Of your vehicle.
14 years 8 months before #19733 by manual-mecanica
Well friend, the most likely to happen to your car is that the battery is discharged, but if the driving engine turns the engine easily the problem is not the battery.
14 years 8 months before #19735 by manual-mecanica
Other times that I have left the car parked without moving for a week or so, and with the cold it is difficult for him
14 years 7 months before #19851 by manual-mecanica
Hello, your Corsa is of injection or carburement? In case it is carburetion apart from the battery it can also be a foot failure ... because if you step too much the gas pedal before giving the ignition you can drown the engine, and if it already costs it in case you turn on (it may be for the age, wired, delco, spark plug Delco, spark plugs or cables.
