Kangoo
14 years 8 months before #19716 by manual-mecanica
Kangoo published by Manual-Mecanica
Hello . I am new here and I require someone's help.
I have a Renault Kangoo and I am disassembling the entire refrigeration and heating circuit because the oil has passed to the water.
I have a problem I do not know how to remove the duct that goes from the water pump to the exit that connects with the radiator or heating,
thanks from Antamano for your help
14 years 8 months before #19717 by manual-mecanica
Manual-Mecanica Answer on the Re: Kangoo
Good afternoon. Tu vehicle Kangoo you have to help you better and the type of vehicle
14 years 8 months before #19762 by manual-mecanica
Hi Edgar, I thank you for your interest, but I already solved it, it is a tube that comes into pressure with a toric joint.
Thank you very much, I will continue entering the forum, it is very interesting
