Automatic cash problem Mitsubishi Coolt
14 years 8 months before #19693 by manual-mecanica
Mitsubishi Cool automatic cash problem posted by Manual-Mecanica
Hello friends, I have a problem with a mitsubishi coolt year 2006. It scanned and we threw us the 32 open change code, the box has been repaired by a specialist.The problem is that when we place change in d the car the car has no strength and the witness of the board of the board destins. Correctly. The box has 4 valves inside that act electrically well. Code 32 refers to the open change solenoid, how do I discard it and where is it located? If in the box it has 4 valves per fabor Nesecito a technical apollo
The box connector has 2 positive cables (1 common for two valves and another common for the remaining two, 2 temperature signal cables and 4 cables that energize the valves, I do not know which of the 4 cables must have energy. When testing voltage with ING comes 12vol in the 4cables they have a negative signal
13 years 2 months before #37180 by manual-mecanica
Manual-Mecanica Response on the topic Automatic Caja Mitsubishi Coolt
Check the box or computer cneptors, see for umentuity in the good luck system.
