Homocinetica de Peugeot 205
14 years 8 months before #19559 by manual-mecanica
Homocinetica de Peugeot 205 published by Manual-Mecanica
Hello everyone I am changing the homocinetic of my car Peugeot 205 and I don't know where the valvulina is put, since when the homocinetic old man lost a lot of valvulo.
Thank you already
14 years 8 months before #19562 by manual-mecanica
Manual-Mecanica Response on the Re: Homocinetica of Peugeot 205
On the velocity box, seen from above, it is stuck to where the maza cable is a plug that at your time is the discharge of precion, be patience that it is a small hole
if you recovered the fluid aggregate it and ready if you do not have to empty it and put 2.5 liters
14 years 8 months before #19565 by manual-mecanica
Thank you very much bari !!!!!
14 years 8 months before #19569 by manual-mecanica
Good afternoon Antonio. The filling and level screw is next to the 5th lid, it is 19m/m. You remove it and add oil until you start leaving, you put, press and go.
The 5th 5th cover is made of sheet
14 years 8 months before #19603 by manual-mecanica
Thank you very much for your help since I get ready
