Gasoline Injection Problem
14 years 6 months before #19206 by manual-mecanica
Gasoline Injection Problem published by Manual-Mecanica
The truck in which I have the mechanical problem is, Chevrolett 1988 Silverado 1500, I was stopped for several months when I stopped by transmission problems, I turned on the engine perfectly, now when I turned it back on, it does not turn on and everything but does not turn on how gasoline does not reach the carburetor, because I put direct gasoline to the carburetor and turn on but turn off but turn off as soon as I burns the gas that I put on the gas. to carburetor.
If you can help me with that, I thank you. Thank you.
14 years 6 months before #19211 by manual-mecanica
Manual-Mecanica Response on the Re: Gasoline Injection Problem
Hello Luis. From what you say it looks like the gasoline pump, which over time can resect and not pump. Call gasoline to the pump and then start with a little gasoline through the carburetor. Remember to be very careful with the gasoline that burns like the dust. Have luck ...
14 years 6 months before #19215 by manual-mecanica
Regarding your question, it can be the carburetor, it needs cleaning has been clogged and does not enter gasoline.
14 years 5 months before #19305 by manual-mecanica
If the carburetor gasoline is harvested, in theory the carburetor is fine.
You can prompt the gum of gasoline that comes from the pump and make attempt to start having if gasoline pulls.
But as the compi has told you, be careful with gasoline.
Greetings
14 years 5 months before #19338 by manual-mecanica
You can make a Pruba you pose to someone to help you by opening the switch and place n direction of the tank to listen to the noise of the gasoline pump.
