I have a Silohuette 97 and I don't mark the gasoline
14 years 8 months before #19023 by manual-mecanica
Good morning you could please help me to know how I fix it to mark my gas and also know why the fans are direct
thanks
14 years 8 months before #19046 by manual-mecanica
Hello, you will see, the issue is to ask yourself if something has been disconnected in this vehicle because it can be the case that when any connector is disconnected, the fans are direct and the same case can occur for the gasoline connector, if you do not have to extract the aphorador to measure the resistance of the fuel meter greetings
14 years 8 months before #19115 by manual-mecanica
Mollilla thank you very much for answering me and now I need to know where the aforer is going to tell me to see if I can remove it.
And how is it done to measure resistance.
thank you.:)
14 years 8 months before #19134 by manual-mecanica
Look at the problem of your fans are directly due to your temperature sensor is possibly disconnected or damaged and how to measure resistance is measured with a digital voltimeter in homs value The resistance should vary as you move the float. I hope and my answer is useful
14 years 8 months before #19139 by manual-mecanica
Dexter23 good day.
But for this I have to do the gasoline tank of the truck disassembly of its base or how he hears and goes very expensive to take it with an electric
greetings.
