Liberty Transmission Failure
14 years 9 months before #19002 by manual-mecanica
Liberty Transcion failure published by Manual-Mecanica
When going circulating, it changes to the third fleece. We stop and start the march and do not develop. It has code d failure P0734 I hope help thank you
14 years 8 months before #19040 by manual-mecanica
Manual-Mecanica Response on the Re: Liberty Transmission Failure
Hello, the wiring failure, sensor/interruptor de marches/shorts of changes of the changes. FAILURE IN THE TRANSMISSION Greetings
14 years 8 months before #19094 by manual-mecanica
Hello S70232J.
P0734 fault code, march 4- Incorrect ratio, as a moth tells you, verifies the solenoid and clean the strainer. Luck.
Miguel
14 years 8 months before #19710 by manual-mecanica
The relationship failure was corrected D Disks of friction, fourth damaged clutch. Thanks for your comments greetings desd Cancun
