Toyota Hilux 2009 Diesel does not turn on
14 years 9 months before #18922 by manual-mecanica
Toyota Hilux 2009 Diesel does not turn on published by Manual-Mecanica
Cordial greetings to the entire mechanical manual community, I have an Hylux 2009 motor 2kdFTV 2500cc Common Rail whose engine does not turn The ECU connector, I have not been able to try the switchboard in another car but I doubt that this is the problem, thanks for your attention
14 years 9 months before #18923 by manual-mecanica
Hello Fabricio.
Does that engine have a camshaft sensor? You would have to check feed air and temperature sensor. Luck.
Miguel
14 years 9 months before #18924 by manual-mecanica
That engine has a crankshaft sensor and a rotation sensor on the injection pump pulley, but not camshaft, the pressure sensor sends 1.4 volts approx, in data flow also read admission air temperature, thanks for the attention
14 years 9 months before #18929 by manual-mecanica
Hello, I would have to try if the currents are arriving at the EDU, it is the computer for the injectors is located on one side on the mud guard I do not know how to send the image of the location or the diagram if you want to send me your email by mp to send it to you and if you want I can also send you the current data volumes and what I had a car of those ke function; I do it when I have a problem is what I stop a car I tell the owner that I am going to give him the diagnosis and I let me check the current data and and until now nobody has been denied me maybe it serves you the tip
14 years 9 months before #18930 by manual-mecanica
The problem I had was that the car came on the road and the car went out of one and there would not be the injectors after a lot of tests that I did discovered that the injection pump did not serve due to Ke Akí in Honduras the fuel is quite bad. What is there they call me, goodbye
