NOTICE IN AUTOMATIC TRANSMISSION OF OPTRA 2007
14 years 9 months before #18877 by manual-mecanica
NOTICE IN AUTOMATIC TRANSMISSION OF OPTRA 2007 Published by Manual-Mecanica
I will appreciate your orientation in knowing whether in a 2007 OPTRA automatic transmission when you warn in the witness light (engine failure) and at the same time it changes the performance of the transmission, which decreases the force and after a while and of turning it out it returns to normal. Is it necessary to change the transmission fluid? or need a greater repair. Thank you.
14 years 9 months before #18886 by manual-mecanica
Manual-Mecanica Response on the Re: Automatic Transmission Notice of OPTRA 2007
Hi Javieres2003.
I think it will be enough to clean the oil strainer, it goes inside the box, luck.
Miguel
14 years 9 months before #18888 by manual-mecanica
Hello, how do you need to take your vehicle to scan since that transmission is electronic only you will know in detail what is what happens nisite is the transmission but some failure in the lucky engine
14 years 9 months before #18932 by manual-mecanica
Hi Javieres2003.
When this situation happens to you, the Hold and the engine is turned on on the board ... of being so it is the sensor to my optra, it was this sensor ... The vehicle loses strength and neutralizes ... Luck
Geoe.
14 years 8 months before #19704 by manual-mecanica
Thank you very much for your orientation, then do you have a strainer?
