MEGAN VELOCIMETRO PROBLEM AND DOORS
17 years 11 months before #1881 by manual-mecanica
MEGANE AND DOORS VELOCIMETRO PROBLEM PUBLISHED BY MANUAL-MECANICA
I have a 2001 Mega Then when circle closes the whole car but marks open door and the light of the closing doors does not turn on, and when the car closes the courtship light takes a long time to go out I have had to remove the bulb in the end
17 years 11 months before #1886 by manual-mecanica
Manual-Mecanica Response on the Re: MEGANE VELOCIMETER PROBLEM AND DOORS
Possibly the sensor that is installed in the gearbox and that sends the speed signal to the instrument frame has been broken.
In that case, it would not mark speed, nor would the mileage rise, and the doors would not close alone either.
Another thing that may have happened is that the speedometer has been broken in itself (the clock) and in that case everything would work except the needle, even the kilometers would rise. But the open door does not fit me, unless it is a different breakdown that has appeared at the same time.
I do not know if I will have helped you, but the only thing I can tell you is that you check the connection of the box speed sensor and if everything is right, you put the diagnosis to see if something strange is found.
All the best.
17 years 10 months before #2045 by manual-mecanica
If your megane has ABS, possibly the velocimeter info comes from there and not a sensor in the box.
I have a 2003 mega that is so and the speedometer signal is multiplexed.
greetings.
17 years 10 months before #2067 by manual-mecanica
Ok, thanks for the clarification, you are absolutely right, the other day I started changing the clutch to a Renault Safrane 2.2 dt and carried the speedometer combined with the wheel signal, but in this case I also had a collector in the box.
Greetings and thanks for being to the parrot!
