Oil in the Spark 2005 cooling tube
14 years 6 months before #18754 by manual-mecanica
Oil in the 2005 SPARK refrigerant tube published by Manual-Mecanica
Greetings, when I went to take refrigerant I found that inside the bottle where it is thrown, there is a yellowish and oily viscosity. I would like to know what can mean. Before I have been told that I must change the crankshaft retain because I have a small oil leak and then I wonder if one has to do with the other. What should I do?
14 years 6 months before #18855 by manual-mecanica
Manual-Mecanica Response on the Re: Oil in the Spark 2005 cooling tube
On occasions they get to do (small) of the antifreeze and it has nothing to do with the retaining of the follow that does not run any cooling vein now the antifreeze is something oily and orange pink green or blue if in your deposit there are coffee or black substance then if there is oil in your antifreeze. luck
