Taseras brake tweezers
14 years 10 months before #18697 by manual-mecanica
Rear Brake Calipers Published by manual-mecanica
Hi, I'm having trouble installing new brake pads. I can't open the brake calipers enough on my Phase I Laguna, and I don't want to remove the bleeder valve because it's very tight and, being aluminum, I'm afraid it will break inside the threads. If anyone knows how I can do it, I would appreciate it.:(
Thanks
14 years 10 months before #18733 by manual-mecanica
Manual-mechanics response on the topic Re: REAR BRAKE CALIPERS
Hi, you're saying you're performing the procedure correctly. The rear calipers are tightened eccentrically, meaning they're tightened and threaded at the same time. But be careful, in some Renault and Nissan models one turns clockwise and the other counterclockwise. Regards.
