Aluminum welding
14 years 2 months before #26388 by manual-mecanica
Manual-Mecanica Response on the Re: Aluminum welding
The procedure for welding aluminum, especially in this type of pieces, is quite difficult, but if you have to weld a tire and do not have experience, remember that the wheels are the only thing that hits your car to the ground ... !!! I would recommend that you take it to some turner to do this work and incidentally machine and check the distribution of weights, so you do not have to put too many weights to balance it ... greetings and luck
