Renault Traffic 1.9 Diesel
14 years 7 months before #18526 by manual-mecanica
Renault Traffic 1.9 Diesel published by Manual-Mecanica
1) I would like to know if you can regulate the valves of my traffic.1999 .. since the mechanic put a totally new cylidos lid ... and says that the valves can only be regulated before assembling and closing the engine ... the problem is that I stay with a
lot It only starts hot whether the calynech twice for 5-6 seconds .. the heating spark plugs are new original bosch and starts as bad as before ..
14 years 7 months before #18530 by manual-mecanica
Manual-Mecanica Response on the Re-Renault Traffic 1.9 Diesel
Hello, you will see in the first place that the one that does not start in hot almost certainly is not because of the problem of the valves. Now, for what you ask about the adjustment, you have to first have Galgar Cojer a note of each valve and then disassemble belt and extract camshaft and recover the precision chavetas, I mean an ostia I hope you are lucky and say what type of motor motors mounts f8q or f9q, k9k q9mr : S
14 years 7 months before - 14 years 7 months before #18562 by manual-mecanica
Thanks for your answer .... What happens is that I don't know what type of motor it is .. I just know that it is 1.9 liters without turbo. and that the cangao also brought it but I will verify it ... and in reality that is the least ... is only noise ... on the contrary the issue that does not start hot .... that is a problem .... According to an electrician, the voltage falls to 10 volts at the time you go and turn the starter engine without starting and says it is low ... being that the battery (willard) of 75 amperes like the original engine (the original) I placed new out of that I consult the injection technician and told me that from there it does not come as a clock .. no smoke throws ... He plug at the PC and is ready and in order everything ...
Latest edition: 14 years 7 months before by .
14 years 7 months before #18564 by manual-mecanica
It's f8q so I could read on the network
14 years 7 months before #18576 by manual-mecanica
Hello, you will see a lucas rotating pump you have to verify if it has a modulus or starting coil (electro valve) if so when they heat up they usually fail (lose the aimantation and foreigner the passage passage, sies with module will have to take the pump and review the module and the pump greetings
