My car endures high
14 years 11 months before #18280 by manual-mecanica
My car holds its own at high speeds. Posted by manual-mecanica
Hello I have a Nissan Navara, the problem is when you are traveling on the route begins to endure I would like to know what the reason can be or that I must inspect to find the fault
14 years 11 months before #18291 by manual-mecanica
Manual-Mechanics' response on the topic Re: My car struggles at high speeds
Hi, I think it could be the pump, the control unit, or some sensor that's faulty and sending abnormal parameters to the control unit. Best of luck.
14 years 11 months before #18304 by manual-mecanica
Hello, you will see you have to specify whether it mounts the Aut box or not and if it is the one of 177 hp because if so these give problems with the Bimasa steering wheel, greetings
