Hiundai Magnus does not work 4th cylinder
14 years 11 months before #18229 by manual-mecanica
Hyundai Magnus 4th cylinder not working. Posted by manual-mecanica
Hello: I have a problem with a 2004 Hyundai Magnus. The issue is that the 4th cylinder isn't working at idle, but it idles normally at 3000 RPM. The spark plugs are new, the spark plug wires are correct, the spark is getting through, and the compression is normal in all 4 cylinders. If anyone can help me, please.
14 years 11 months before #18239 by manual-mecanica
Manual-mechanics response on the topic Re: HYUNDAI magnus 4th cylinder not working
Hi, we'll have to start by checking the coil, primary and secondary, obviously ruling out that the cables are original and that there's no wiring confusion.
14 years 11 months before #18245 by manual-mecanica
First, check that all the wires have spark, and check the injectors because I think that might be your problem.
14 years 11 months before #18263 by manual-mecanica
THANK YOU FRIEND X YOUR HELP
