CLUCTH MAZDA B 2500 CHANGE
14 years 11 months before #18172 by manual-mecanica
CLUCTH MAZDA B 2500 CHANGE PUBLISHED BY MANUAL-MECANICA
That such lords I want to tell you that I am changing
the clucth to my Picop
I am currently in the last face but I do not know why the box does not come in the box and I would be revised that the album was well focused and all its component but still does not enter
you believe that it is for the collar bomb that uses if someone can help me with this topic I thank you for
greetings ...:)
14 years 11 months before #18184 by manual-mecanica
Manual-Mecanica Answer on the Re: CLUCTH MAZDA B 2500
If you have changed clutch disk, I suggest that you disassemble it again and compare it with the one used possibly the milling is not the same and that is why it does not enter the axis of command.
