I have a problem with a Seat Toledo from 98
14 years 11 months before #18151 by manual-mecanica
I have a problem with a Seat Toledo of 98 published by Manual-Mecanica
I have a problem with a Seat Toledo Tdi of 98 of 90 hp. In the fuel food sstema it does not reach the ducts of the Avia Avia Medium Tank injectors, it will be:
- That the injector pump is evil
- Any relief
and how can I burge it if it has no bombin or electric pump?
Thanks for the rspuest ...
14 years 11 months before #18152 by manual-mecanica
Manual-Mecanica Answer on the Re: I have a problem with a Seat Toledo of 98
Hello, you have tried to see if current comes to the valve that is in the injection pump, try it by taking the cable with a small key of key No. 8, take the cable and with the given contact, you make it touch and the valve has to make a small noise like a clack clack clack, if it makes that noise you already know that the valve is not, it is what I think of
14 years 11 months before #18156 by manual-mecanica
Hello, so looking if you have air in the circuit? To purge you can buy a pear (purge pump) of some cytroen carries almost everyone and mount it in yours, or removing the duct that goes to an inynector and you give the start -up until it starts (sessions of 5 to 10 seconds and waiting between each session for at least 30 seconds Broken filter (a), or the antirector valve of the injection pump is evil, which motor you have 1.9tdi 66kw.un greeting.
