4 -cylinder perkins motor problem
14 years 11 months before #18036 by manual-mecanica
4-cylinder perkins motor problem published by Manual-Mecanica
A 4 -cylinder Turbo Perkins engine was repaired, but at the time of calibrating valves I did it at 25 exhaust and 23 admission ... would I know why smoke comes out of the delage but is burning oil?
If the calibration process performed is what would be your correct calibration?
I await your great help
thank you
14 years 11 months before #18038 by manual-mecanica
Manual-Mecanica response on the Re: Motor problem with 4-cylinder perkins
Could you indicate the motor model to help you better?
14 years 11 months before #18048 by manual-mecanica
Hello heavyooo.
As JAPCPDS told you it is necessary to know the model and also what kind of repair. The smoke due to the venture is caused by speech guides, worn, broken, glued or poorly placed rings, grated cylinder or rings with poor settlement due to the oval of the cylinder, there are other factors but I do not want to be pessimistic. Luck.
Miguel
14 years 11 months before #18078 by manual-mecanica
I believe that the valves have nothing to do, you checked that the turbo does not burn oil, you checked its status. the axial game of the same and longitudinal.
14 years 11 months before #18158 by manual-mecanica
It was a partial repair change of rings and change of capchones of the valves.
