ELECTROS PEUGEOT 306 problem
14 years 10 months before #17987 by manual-mecanica
ELECTROS PEUGEOT 306 problem published by Manual-Mecanica
Well, gentlemen I have a problem in the electros. I have tried to disconnect the temperature probe connector and when I disconnect it if they work.
temperature probe or thermostat fucking ??
greetings
14 years 10 months before #18039 by manual-mecanica
Manual-Mecanica Response on the Re: Electros Peugeot 306 problem
Most likely thermostat. A greeting.
14 years 10 months before #18071 by manual-mecanica
If you disconnect the electro temperature sensor because it is in a state of emergency, try the first speed of the electro if it is good, but the best thing to do in that case, between which you are looking for all the compounds that is a real can and reverend problem and very expensive is to perform a parallel installation, it is not expensive and if you know a little electricity you can do it yourself, but check if you have a temperature Chile there are Peugeot 306 that bring it and others that do not.
