Back light
14 years 10 months before #17960 by manual-mecanica
Reverse light published by manual-mecanica
I would like to know where the Nissan First Reverse switch is with P-10 / 2.0 engine, and that must be disassembled to have access to it.
Greetings and thank you very much
14 years 10 months before #17963 by manual-mecanica
Manual-Mecanica Response on the Re: Reversing Light
Good compi, it is a bulb that activates the gearbox has two lines, a positive and one return, it is only a matter of throwing yourself under the machine and looking for it, greetings Compi.
14 years 10 months before #17977 by manual-mecanica
It is mounted on the gearbox, but not on the side of the shell but in the very body of the gears, it has two cables and it is not difficult to replace because it is mounted on the outside, that is, you do not have to take the box, according to it I remember it, if you will have to put together in patience because this operation must be carried out under the vehicle.
14 years 10 months before #18032 by manual-mecanica
Thank you very much Kikemec, I have already found it.
All the best
