Abnormal water consumption
14 years 11 months before #18043 by manual-mecanica
Manual-mechanics' response on the topic Re: Abnormal water consumption
In Chile, pharmacies sell a product that mechanics call "liquid glass."
You pour a liter of it into the cooling system and drive the car. As the water drains out, the liquid hardens and seals the leak, whether it's internal or external. Once the leak stops, you drain the radiator, wash the engine, refill the coolant, and the problem is solved.
, we tried it, and it worked.
14 years 11 months before #18046 by manual-mecanica
Those cars often have the heater core reservoir come loose. I have a 2006 Hyundai and the same thing happened to me. Check if the carpet inside the cabin is getting wet; if so, that's the problem.
14 years 11 months before #18076 by manual-mecanica
That's true, Rorito, I've used it and it works well. Of course, there's also block sealant if you can't find liquid glass, also called soluble glass.
14 years 11 months before #18260 by manual-mecanica
Thank you again for your support, I will do what you have recommended and then I will let you know.
14 years 11 months before #18272 by manual-mecanica
If you do not lose water anywhere and consume it, do not give any more turns that is the butt joint and more calling Hyundai throw you a lot of water vapor through the escape, luck
