Rear antinieblas
14 years 10 months before #17938 by manual-mecanica
Rear antinieblas light published by Manual-Mecanica
Good morning friends, my question is as follows, I have a 306 TD year 95 The problem is with the rear antinieblas light melts all the fuses that I put when I connect it, I have to have a short one in some side but I do not find it, I have followed the cable from the rear pilot but I lose it and I do not see anything, can it be that the short tries the same switch button? I am a little lost thanks in advance and greetings to all the foreros
14 years 10 months before #17941 by manual-mecanica
Manual-Mecanica Response on the Re: rear anti-nbolian light
If it is a possibility that the cut is aga by the button, or it can be the fault of the sole of the light, or already clearly wired, the button with a tester or the sole that does not gather this you do in the continuity function, but check the sole
14 years 10 months before #17954 by manual-mecanica
Thanks Kikemec for your note, I imagine that the soquete will be the support where the bulbs are hooked, if so I have already tried it with another that I have and remains the same, I will look at the Tester that you tell me and I will tell me. Safe to all and Merry Christmas
14 years 10 months before #17957 by manual-mecanica
Good greetings, it would be recommended that you discard short circuit by measuring with tester if the insulation has dropped with respect to the chassis, then measure with respect to other cables, a consultation was the car repaired by a chapist?
Even if it has been ATRS time that may be the cause. We expect news.
14 years 10 months before #18057 by manual-mecanica
Very good, because of what you say the car has not had any blow, regarding testing this weekend I will look at it in the town because I have it there and I have to pass the ITV now and I do not know if they will pass it to me without working that light. What do you think of this? Thanks a greeting
