Air conditioner system
14 years 10 months before #17925 by manual-mecanica
Air conditioner system published by Manual-Mecanica
Estimated senhores.
They could help me with the following doubt.
My car is a Toyota Hilux 2008, one day ago it is presenting me problems with the refrigeration
when I turn on the car and I cool well but suddenly turns off the compressor and I have to stop the A/C key of the board so that it works again.
The normally cooling at the same temperature, I have ruled out that it is lack of gas and oil inside the pipelines.
My question is how I can locate the real fault of this problem and how could I solve it?
Thank you
14 years 10 months before #17940 by manual-mecanica
Manual-Mecanica response on the Re: Air Conditioner System
From what you say it can be the problem of the changing button and test are not expensive and for the test you can occupy any alternative button that they sell and be economical, it may be heated and disarmed or disarmed by vibrations.
13 years 11 months before #28971 by manual-mecanica
Friend the problem was a resualto as follows.
It was tube that replace the clutch, it was had to change the evaporator filter and change the valbule.
Now if you cool the beers well.
Thank you.
