strange sound
14 years 10 months before #17898 by manual-mecanica
Estraño sound published by Manual-Mecanica
Hello everyone, I would like to know the opinion about a sound that Ace my car is a renault Scenic2 with 1.5dci engine and 102mil km and since the cold started when the car starts and for a while it sounds like clicking like the
taque A quick but very suab click
that you think
14 years 10 months before #17900 by manual-mecanica
Manual-Mecanica Answer on the Re-rare sound
Injection problems
14 years 10 months before #17912 by manual-mecanica
Good compi, it is not very specific what you have but apparently lack lubrication to the engine, you could start with the oil pressure and verify if you are in the right pounds, it is possible that valvulates for this reason, greetings compi
14 years 10 months before #17991 by manual-mecanica
Well, the truth is that at least it sounds to me at least what Ace about 2000 to 3000RV since I think I began to approach him to change the distribution strap and say that I change it with the user that indicates the manual and say that if it was put as the manual says the engine seemed that it was going to break from how strong and that more than 10,000km that was given and not given any problem if the noise of when it is cold is when the oil is changed every 15,000km next to the filter and use Repsol 5W40
14 years 10 months before #18064 by manual-mecanica
Saves I believe that your problem is that some of the hydraulic taquis is discharged and that is the noise in low, whether it is downloaded or does not load well it will sound to you in high, it would almost say disappear but it sounds very finite.
