Peugeot 206 HDI
14 years 10 months before #17865 by manual-mecanica
Peugeot 206 HDI published by Manual-Mecanica
Hello everyone, I have a Peugeot that by distraction they put a new battery with the alcontrarium terminals, spark and smoke was rapid (according to the owner) now the vehicle when opening contact is activated the pens and when giving it on it only feels click on the starter and feels as if the battery is discharged. I will be attentive to your opinions thank you ... Peugeot 206 HDI turbodiesel 2006
14 years 10 months before #17875 by manual-mecanica
Manual-Mecanica Answer on the Re: Peugeot 206 HDI
There is no other the short of several cables, the solution is to disassemble the installation and rise :(
14 years 10 months before #17885 by manual-mecanica
Thank you for your interest ... the vehicle started but with the old battery as it was discharged, we passed it, we turned a few laps and the lights were turned off and the Stop indicator flash lost strength, we stopped for a while and again started but then went out and after a cute time it starts again; I have suspicions that the alternator regulator is not loading the battery because of the small short, I will be attentive to your comments thank you ...
14 years 10 months before #17910 by manual-mecanica
The easiest thing is that the switchboard has been broken. I spend in a 2003 Ibiza. Greetings
14 years 7 months before #19857 by manual-mecanica
Hello everyone and sorry for the delay out outside .... the problem was solved just changing the battery, thank you very much for your interest bye ...
