DW8 motor distribution strap problems
14 years 10 months before #17755 by manual-mecanica
DW8 motor distribution strap problems published by Manual-Mecanica
Estimated, I consult you about a problem that I have with a 1.9 d engine DW8, the distribution strap oscillates, we already changed all the outside pulleys (cams, crankshaft, injection pump), tensioners, strap, axials, we control the injection pump in a test bench and it is aligned, we put all the original spare parts, compare the pulleys and are aligned.
Anyone who can help me?
14 years 10 months before #17761 by manual-mecanica
Manual-Mecanica Response on the Re: Problems Dist Distribution Correa DW8
They checked possible radial game on the drive axis?
14 years 10 months before #17795 by manual-mecanica
JECAR:
If you refer to the game in the axials, in the crankshaft. They were walked.
If not, I don't know what you mean with action axis
greetings, Carlos
14 years 10 months before #17821 by manual-mecanica
Have you proven water pump ???
14 years 10 months before #17858 by manual-mecanica
We change it for a new one.
