Urgent help
14 years 10 months before #17696 by manual-mecanica
URGENT HELP PUBLISHED BY MANUAL-MECANICA
I have problems with an Alfa Romeo 145. The Check Engine was lit and I need to identify the fault code and then erase it. I don't have the diagnostic instrument. Can the operation be carried out without the instrument? From Yá very grateful
14 years 10 months before #17700 by manual-mecanica
Manual-Mecanica Response on the Re: Urgent Help
hi how are things. What displacement and what year is your alpha?
14 years 10 months before #17709 by manual-mecanica
Year 97 'and the displacement 1.6
14 years 10 months before #17710 by manual-mecanica
Check Engine always refers to a bad combustion, is activated by a sensor that adds the exhaust gases so the failure should be either in the injection system or the primary electrical system, you would kill you that the checks, at times it is something as simple as a change of spark plugs or cables. luck...
14 years 10 months before #17715 by manual-mecanica
hello.
The injection system of your car does not present the OBDII diagnostic management which is the standardized system for a breakdown. There must be a diagnosticator substed by the representative, or take it to a specialized technical service to submit it to a revision. To all this, have you noticed any change in the operation of your engine?
Tell us.
