Seat Ibiza of 97, it is hard for you to start
14 years 10 months before #17618 by manual-mecanica
Hello everyone, I am new in the forum and my problem is two:
1st-I find it a
lot A time, I usually remove the cover of the ofco and throw 3 in 1 and usually work, also change the cables of spark plugs and spark plugs, air filter.
I hope you can help me, thanks in advance
14 years 10 months before #17803 by manual-mecanica
nobody knows anything or some place where to look
14 years 10 months before #17806 by manual-mecanica
Do you mean that when you give the start, it does not put any kind of bouya or try to do something? Or just does nothing if it does nothing can be the problem of the plate on the sheet, if it tries to do something it may be missing powerful spark or drowns by a bad signal of the temperature or oxygen sensor.
14 years 10 months before #17827 by manual-mecanica
Nothing at all, when he takes, that was not even well
14 years 10 months before #17848 by manual-mecanica
It has to be the sheet of the sheet, and its control module, try the start of direct bridge to rule out the problem
