Nissan Almera Power Loss
15 years 3 weeks before #17399 by manual-mecanica
Nissan Almera power loss. Posted by manual-mecanica
Greetings everyone.
Could someone please tell me what might be causing a loss of power in a 2004 Nissan Almera?
Thank you in advance.
15 years 3 weeks before #17402 by manual-mecanica
Manual-mechanics' response on the topic Re: Loss of power Nissan Almera
Well... first of all, I think you should do a more in-depth diagnostic check. You should test if any cylinders aren't firing. I should mention beforehand that this type of car tends to have one or two ignition coils fail, which are obviously controlled by the ECU, or engine control unit. Also, check the catalytic converter... Anyway, I'm here to help.
15 years 3 weeks before #17405 by manual-mecanica
Hi, I'm Alex a Nissan N16 gasoline? It is the caudalimetro
