Service 4WD Swith
14 years 11 months before #17367 by manual-mecanica
Service 4WD Swith published by Manual-Mecanica
:( I have a Grand Cherokee Limited 1995, in the dialogue center the legend appears that it is necessary to service to the 4WD Swicht ,, how is this .. also someone knows what kind of oil it carries the automatic transmission, it is of any kind or should it be a special type?
14 years 11 months before #17383 by manual-mecanica
Manual-Mecanica Answer on the Re: Service 4WD Swith
Hello Ajaimes,
the Chrysler recommends for its automatic boxes the MOPAR ATF Plus3 Type 7176, if you do not get that question for the equivalent in another brand. On the legend, check the double traction change selector. LUCK
MIGUEL
14 years 11 months before #17384 by manual-mecanica
Thank you very much, tomorrow the first hour is the first thing I will do, check the double selector, and as for the oil you must carry, I will look for first in the egncia. Thank you very much again. . :)
