Peugeot Boxer does not start hot
15 years 1 month before #17159 by manual-mecanica
Peugeot Boxer does not start hot published by Manual-Mecanica
Hello good, I have a Peugeot Boxer 2.8 HDI year 2000, the problem is that it starts perfect but when it heats and unemployment does not start again until it is again cold, if anyone knows what can be ??? It does not have a good battery shots, well -set heater well etc. Greetings thanks !!
15 years 1 month before #17176 by manual-mecanica
Manual-Mecanica Response on the Re: Peugeot Boxer does not start hot
Queo that you should check the engine, can be the water temperature sensor, greetings
15 years 1 week before #17746 by manual-mecanica
Hello, to see if that fault helps you that you comment as sure is a fucking injector, the diesel is returning for the deposit.
When there is an injector screwed into a Common Rail system, it starts better in cold than hot and with an injector tester you know immediately which one that does not work well. I hope I have helped you, luck.
15 years 1 week before #17747 by manual-mecanica
Good compi, in the workshop I spent exactly the same with a Mercedes Sprinter of 2008 and it was the starter or starter motor that hot did not give the laps that a diesel needs to start. Fix if in cold it gives the same laps as hot as hot, I know that it does not sound very logical but that was the reason, new starter engine and the problem is over ... Greetings
15 years 1 week before #17757 by manual-mecanica
Hi, I'm from the same opinion as the Mot electro forum partner
