Spark 2005 oil leakage
14 years 11 months before #17121 by manual-mecanica
SPARK 2005 OIL EQUIPE PUBLISHED BY MANUAL-MECANICA
My spark is driving me oil, the mechanic tells me that it is a leak that is just starting and that the origin is because of the back with the back, however, he tells me that he has to lower some boxes and that in that case I recommend changing the clutch kit to make a single descent ... my problem is that my pocket does not give ... I do not have the money to do both, how much should I change the clutch kit? How can I solve that leak?
14 years 11 months before #17132 by manual-mecanica
Manual-Mecanica Response on the Re: Spark 2005 oil leakage
The kit is changed very rare every 1 anus or more if you want geo are agglo Lamame 61086788 Mechanica Alberto very cheap
14 years 11 months before #17151 by manual-mecanica
To change the crankshaft retain if it is necessary to lower the gearbox, but it would not That he will change you and what he tells you is only to help you charge you the same for the retain or for the kit.
