Fixed airbag light problems
15 years 1 month before #17096 by manual-mecanica
Airbag light problems fixed by manual-mecanica
Hello good I have problems with my fixed airbag light on my Renault Megane is 4 years old and on the computer it makes me check airbag I would like to know what to do thanks.
15 years 1 month before #17104 by manual-mecanica
Manual-Mecanica response on the Re: problems with fixed airbag light
Try to disconnect and connect the cables under the seats, sympre with the contact removed. If when putting the contact you do not go out you must go to the mechanic and check it with a diagnostic device. I hope it serves you.
15 years 1 month before #17105 by manual-mecanica
The first thing you should know is that with the light on you do not have airbag. Well, first go to the car to see what Airbag fault you get out. If you go to the ITV with the light on you will not pass the same. If you do not want to fix the problem, you have to disassemble the picture and cover that light since those of the ITV cannot throw you back even if the previous check is not carried out, they only look that the light is not on, but you already know that you do not have the airbag.
15 years 1 month before #17125 by manual-mecanica
Thank you, I'm going to see if I'm lucky.
15 years 1 month before #17129 by manual-mecanica
Geo Agabo to Quitar the Erbeg I Bombilea when they passed the ITV, they asked me why it is not instilled when I put the contact and I could not pass the ITV
