My Clio 2004 does not start
15 years 4 days before #16966 by manual-mecanica
My Clio 2004 published by Manual-Mecanica
I have a 2004 automatic clio and in the morning I have a lot
15 years 4 days before #16971 by manual-mecanica
Manual-Mecanica Answer on the Re: Do not start my Clio 2004
First, the first thing Czech filters and spark plugs, if everything is good to check the temperature sensor that is not out of Rrango this is the first.
14 years 11 months before #17022 by manual-mecanica
Hi, I'm Alex. problem you have is the steering wheel collector {the rpm sensor}
14 years 11 months before #17035 by manual-mecanica
Thanks for answering I will take it to Checar and I tell you ok see you soon : blush:
14 years 11 months before #17345 by manual-mecanica
Greetings scanned him and found nothing and told the mechanic to change the crankshaft sensor and the temperature and the pairser was well but it takes to enter the fan and heat up until the antifreeze will throw the antifreeze will have to see the sensors or it is something else in advance thanks for helping me.
